Scoop66
May 16, 2021Follower
NETGEAR N150
I recently upgraded my computer from Windows 7 to Windows 10. I am using the Netgear N150 WNA1100 wireless adapter. I had Internet connection for a few weeks. Now I can't connect to the Internet on my...
May 16, 2021Guru - Experienced User
what driver are you running.
Supposedly it supports windows 10 but its an old adapter. and windows could have pushed an update that breaks compatibility. It wouldn't be the first time. It might be time to upgrade from a N150 wireless adapter
https://www.netgear.com/support/product/WNA1100.aspx#download
