AlexSotheran
Apr 07, 2021Guide
Netgear N300 Range Extender Not Working? Need help troubleshooting
I am trying to connect my Netgear N300 to my Virgin Wifi (2g) for use in the loft. The extender connects to the device, but not the router, I've followed the instructions to the letter several times ...
Apr 07, 2021Guru - Experienced User
what virgin router is it?
Where is it failing in the process?
That's kind of key.
Have you tried using wps?
AlexSotheran
Apr 07, 2021Guide
The Virgin router is a superhub 2ac, I tried WPS and no joy there at all, so I tried the installation assistant, I get to the point 10 in the quick start guide: make sure the computer is succesfully connected and click CONTINUE. I then get a message saying it is not connected.
- plemansApr 07, 2021Guru - Experienced User
at that stage you already should have set a name for the extender. Did you setup a custom name for it? (make sure not to use the same name as the router)
Did you connect your pc/laptop to it?
- AlexSotheranApr 07, 2021Guide
Yes to all that, I just followed the quick start guide. The light was green on the Power, WPS and Device, but nothing on the Router.
are you hardwired into the router during setup?
What error does it give you?
