JHagles
Jul 06, 2022Tutor
Netgear N600 Router Access Not Working
I recently had the power go out in my home and our N600 modem/router seems to have reset to the default settings. The router still works, with more intermitent internet drops than usual. However when...
Jul 06, 2022Guru - Experienced User
What actual device do you have? N600 is a speed, not a model.
Did you try accessing it at 192.168.100.1?
- JHaglesJul 06, 2022Tutor
Model number is C3700
And yeah connecting by 192.168.100.1 also brings me to the following page:
- plemansJul 06, 2022Guru - Experienced User
What happens if you go through the activation process?
The router is activated on the service providers side. When I select the service provider on the router login page it says to contact Spectrum to activate the equipment, but the router is already activated in Spectrums system (I called to make sure) and providing Wifi.
