GerardP
Apr 29, 2020Aspirant
NETGEAR N600 Wireless Dual Band Router
I took delivery on the router last week. When I use the serial number printed on the product (checked & rechecked) to register the product, I get the following message: “This serial number is already...
- Apr 30, 2020
Sounds like you bought a used/refurbed unit.
Registering isn't exactly needed as it enables access to support/warranty. Which i doubt that device has since its was made in 2014. Originally in 2010. Paying for support for it at this time would be more expensive than that router.
You can get it back to factory settings. While its powered on, push and hold reset for 7-15 seconds. The lights should flash. this should get you back to stock and then you can go through and set it up.
Apr 30, 2020Guru - Experienced User
GerardP
May 11, 2020Aspirant
The response to my issue was a clear clue that led me to returning the router to the vendor. Thank You
