LightninBob
Mar 01, 2016Aspirant
Netgear N600 WNDR3400v3 CAN'T GET MY IP PHONE TO REGISTER CISCO 504G
When connect to my router, phone will not register. My IT dept. suggested to connect phone directly to the cable modem, when I did that, the phone registered. The IT dept said the router is blocking ...
- Retired_MemberMar 01, 2016
advanced ....setup.....wan setup....if the router has the option to disable it
Retired_Member
Mar 01, 2016advanced ....setup.....wan setup....if the router has the option to disable it
