jdemoccc
Apr 18, 2017Aspirant
Netgear N600 WNDR3400v3 not full download speeds
so we have a 250Mbps down x 50Mbps up line. We just installed a Netgear N600 WNDR3400v3 and i ran speed tests and we are only reaching about 95Mbps download. The upload is consistent at 50Mbps. If we...
- Apr 18, 2017
ok so just read that this router only will do a maximum of 100Mbps wired. Could someone recommend a router that will work for my 250Mbps line? will the N900 work?
jdemoccc
michaelkenward
Apr 19, 2017Guru - Experienced User
jdemoccc wrote:will the N900 work?
There is no N900. That is a wifi speed.
You need to look for a router that has 1000 Mbps LAN.
As you say, the WNDR3400v3 has 100BASE-Tx LAN. Most newer routers have 1000BASE.
Just browse the product pages and look for something that meets your needs.
