Dane_B
Jan 05, 2016Aspirant
Netgear N600 WNDR3400v3
I want to use a WNDR3400v3 as Repeater for an existend Arris_Kabel-TV_Modem_Wlan-Router. I need the Wlan Signal at the Place where the Arris is placed, also I need the Wlan Signal where the WNDR3...
- Jan 06, 2016
I do have a Cable between AP and router.
I tried vor some hours, but if I set AP-Mode on WNDR3400v3 its just the W-Lan working and not the ports for the fix cabeld stuff.
so I put the DHCP on again, I set the W-Lan settings at the same as they are on the Router.
and now it is all working in one network.
Thanks for all your help.
Anonymous
Jan 05, 2016Repeater mode doesn't seem to be available on this router. If it was I would think that option would be listed in the manual.
- Dane_BJan 06, 2016Aspirant
Ok so the guy in the shop, sold me the wrong thing...
do you know an produkt i could use?
- AnonymousJan 06, 2016
Assuming you what to improve/add WIFI coverage? How would you connect to main router? If you have Catxx cable you could use almost any router in AP Mode or as a AP But, this requires a cable connection between AP and router.
