Dane_B
Jan 05, 2016Aspirant
Netgear N600 WNDR3400v3
I want to use a WNDR3400v3 as Repeater for an existend Arris_Kabel-TV_Modem_Wlan-Router. I need the Wlan Signal at the Place where the Arris is placed, also I need the Wlan Signal where the WNDR3...
- Jan 06, 2016
I do have a Cable between AP and router.
I tried vor some hours, but if I set AP-Mode on WNDR3400v3 its just the W-Lan working and not the ports for the fix cabeld stuff.
so I put the DHCP on again, I set the W-Lan settings at the same as they are on the Router.
and now it is all working in one network.
Thanks for all your help.
Retired_Member
Jan 06, 2016Assuming you what to improve/add WIFI coverage? How would you connect to main router? If you have Catxx cable you could use almost any router in AP Mode or as a AP But, this requires a cable connection between AP and router.
Dane_B
Jan 06, 2016Aspirant
- Dane_BJan 07, 2016Aspirant
I forgot to wrote two points:
i set an fix IP-Adress at the Arris Router.
on the WNDR3400v3 I had to set the AP-Mode off.
