Jgray27408
Feb 02, 2023Follower
Netgear n900 wireless dual band wndr4500v2
I am switching out my WiFi router to a different brand. It still works just old. Problem I want to either donate or recycle it but the password is listed on the equipment. I want to either change the ...
michaelkenward
Feb 02, 2023Guru - Experienced User
If that is the password on the label – and not just something you wrote on the thing – a reset won't change that. It is there by default. But there is no security risk. It won't be on your network,
When someone buys a new router, Netgear goes out of its way to urge you to change the Wi-Fi password.
In the decade since your wndr4500v2 was released, security concerns have become so important that newer routers try to prevent you from using that default password beyond the setup stage.
