mediatrek
Mar 29, 2016Virtuoso
Netgear needs to correct their site's WiFi Routers product page
Netgear has had some “cleaning up” to do on their WiFi Routers product page for some time now. First off, why does Netgear list on the page products that are EOL (end of life)? Get them off the page with the new products that they still actually support. Which models are EOL that you list that are on the page? There is the two CENTRIA models (WNDR4700 & WNDR4720), then there is also the WNR2200 and WNR3500Lv2.
In addition, you should update the Nighthawk X4 (R7500) product page to reflect the R7500v2 as that is what is out mostly on store shelves now for the past few months, and also as you have the original R7500 as an EOL product as well.
This is acknowledge and thank you for providing a feedback.
I will go ahead and forward it to the management.
1 Reply
- ElaineMNETGEAR Employee Retired
