spike66
Dec 07, 2022Follower
Netgear Night Hawk AC1750
the 5G signal on my Netgear AC1750 suddenly became very weak. Only discoverable if I am right next to the router. Even then the signal is to weak to connect. I’ve tried the reset button and powered of...
Dec 07, 2022Guru - Experienced User
What actual device do you have? AC1750 is a speed.
It might be the hardware failing or the firmware causing the issue.
You can try reinstalling the firmware and doing a factory reset afterward and see if it works.
If not, you can try downgrading a version in case its an issue with the version you're on.
You can also try changing what channel the 5ghz is broadcasting on.
