RAMiller
Mar 24, 2022Follower
Netgear Nighthawk AC1000 USE OF ETHERNET WITHOUT WIFI TURNED ON
I was under the impression I could turn off the Wifi switch on this model router and still be able to use the Ethernet ports. I downloaded the app and installed the router with no problem. However i...
Mar 24, 2022Guru - Experienced User
Thats odd. You should be able to connect any ethernet device to the LAN ports and get internet services. Disabling of the WiFi doesn't not effect the wired LAN ports.
Can you disable the wifi radios from the routers web page under Advanced Tab/Advanced Settings/Wireless Settings?
