JakeMN
Dec 30, 2022Tutor
Netgear Nighthawk AC1750 router ethernet really slow but wifi is fine
Hi, I have the Nighthawk AC1750 router and I have been having troubles with the ethernet. I have 400 mbps download and I was getting the full 400 on ethernet a little bit ago but all of a sudden I am ...
- Jan 17, 2023
You are more than welcome. Please mark this as resolved. If you have issues down the road, start a new thread.
michaelkenward
Dec 31, 2022Guru - Experienced User
Let's start with the usual boilerplate questions to rule out the obvious.
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router. That can complicate troubleshooting.
What do you see in Show Statistics for your Internet Port? Anything odd in the Status column and the speeds of the LAN links?
JakeMN
Jan 17, 2023Tutor
Are you able to help me? I’m still having the same issue.
- KitsapJan 17, 2023Master
Connect your computer direct to the modem without the router in between, and test your throughput. What do you get?
Recommend you use the Ookla native test application for your operating system. It is available from the Playstore and this eliminates the web browser as part of the test.
Please confirm the full model number of your router. Look on the label. Is it R6700???
