tyfloww's avatar
tyfloww
Follower
Nov 30, 2022
Netgear Nighthawk AC1900
Im using a pc that has a motherboard that doesn’t come with wifi. Im trying to setup my PC, but it requires me to connect to a network in order to continue the setup. I just need assistance on using the wifi adapter to connect to my wifi
1 Reply
  • plemans's avatar
    What adapter do you have?
    AC1900 is a speed.
    What I see done a lot is downloading the driver on another pc that does connect and transferring it via jump drive/flash drive to the non working pc so you can install the driver. have you tried this?
