PhillipStone00
Feb 16, 2019Aspirant
Netgear Nighthawk R7000-100NAS Dual Band Wireless and Ethernet Router, Black
Hello, I had seen the newest
Netgear Nighthawk R7000-100NAS Dual Band Wireless and Ethernet Router, Black. On an At&t forums and I was wondering if that this type of router/gateway would work thr...
- Feb 19, 2019
PhillipStone00 wrote:
I think as to what I had asked is pretty straight forward question?
Only if you provide enough information.
The R7000 is a router. Unless you have something like fibre broadband with its own terminal, a router needs a modem of some sort in front of it.
If you ask Google to tell you about the "2Wire 2701 HGV-B", the results are confusing. It looks like an ancient piece of kit that might also be a router. If so, then you will have to work out how to turn off its router bit.
To get more Ethernet ports, all you need is a simple switch.
SOHO Ethernet Switches | Switches | Networking | Home | NETGEAR
Home/Office Ethernet Switches | Switches | Networking | Home | NETGEAR
PhillipStone00
Feb 19, 2019Aspirant
Why are you baffled? I think as to what I had asked is pretty straight forward question? I had asked if that this type of router would work with At&t Internet? The router that I currently have is a 2Wire 2701 HGV-B(Black) I'm looking for a router/gateway that has atleast 4 port's on the back of the router in order to connect my smart tv and gameing system along with connecting my desktop computer to Ethernet.
michaelkenward
Feb 19, 2019Guru - Experienced User
- PhillipStone00Feb 23, 2019Aspirant
This post isn't about the Model that I had to choose in order to post to the communities. How ever it is on the post of "2Wire 2701 HGV-B" router. Yes I do know it's an anciant router but that is the router that the technician had ordered for me at the time of the install? And also at that time I was a new customer as well, I didn't think that I could ask for a better router than the one they had sent to me?
But I have found a new router that is from Netgear products, which is the NETGEAR N750 Dual Band WiFi Router, 4-Port Gigabit Ethernet (WNDR4300) and also this one Netgear AC750 Dual Band Smart WiFi Router (R6020-100NAS) my question/question's is can either of these router's work along side or replace the current router that I have now? Can either of these routers work with At&t Internet carrier? Which is what I have now plus I also have At&t DirecTv. And if they do work with the carrier I had described how much would each one run me price wise? And can I order one or the other from Netgear and or does anyone know for sure if that At&t would carry the two types of routers? Or would I have to order one or the other from Netgear itself?
Thank's.
- michaelkenwardFeb 23, 2019Guru - Experienced User
This post isn't about the Model ...
It is if you want meaningful answers.
How ever it is on the post of "2Wire 2701 HGV-B" router. Yes I do know it's an anciant router but that is the router that the technician had ordered for me at the time of the install?From what I can see, which isn't a lot, it is a modem router which is not the same as a router. The difference is crucial.
Those are both routers. They cannot replace a modem.
If you can put your existing device into modem only (bridged) mode, then either would work. Both are bottom of the range routers.
If the idea is to replace this "2Wire 2701 HGV-B", I would start by telling people what your internet service is. DSL? Cable? Fibre? How fast?
Then decide if you want to replace the existing box with a single modem/router, or if you want to add a router to this thing.
If you want to do that, you need to see if it is possible to put your device into modem only mode.
Perhaps now you can see why your first message was too cryptic to allow sensible and informed answers.
To be honest with you? I'm not sure of what type of router it is that I currently have? But it is a DSL model and it is a router that much I do know. It's not a modem I had gotten it from At&t Internet service carrier they had ordered it for me at the time of the install on day one. Again it is not a modem it's a wireless router. It's one of their older models of routers that they have. At the time of the technician that had ordered it for me I was a new customer and I wasn't sure if I could ask for a better router than the one I currently have being as at the time I was a new customer and I wasn't sure if that they do have better routers? Also I had checked on there website of the newer routers that they do carry but on their webpage they only have the one newer router which has atleast 4-ports on it the router that I have now only has the one port for my desktop computer. But I'm looking to either buy and or to lease a new router that has atleast 4-5 ports on it. So that I can connect my desktop and gaming systems and my smart tv to it. I do not have a screenshot of it being that I'm on my desktop now. (Of the router screenshot)
