joaquincreixell
May 04, 2021Follower
NetGear Orbi RBK753
Hi everyone, Just want to make sure if the ethernet ports of the RBK753 can be used as inputs or outputs. I mean, they only come with two ports: ¿can i use them either as input or output? Reg...
May 04, 2021Guru - Experienced User
There isn't a "input/output" port. Lan ports are bi-directional.
There is a wan port for internet service.
The other lan ports can be connected however you prefer to devices/switches/etc.
