arfanvilla's avatar
arfanvilla
Follower
Jul 29, 2021
Netgear Power Led blinking red DGND3700v2
Hi all
My netgear router (DGND3700v2) power light keeps blinking red.
No other LEDs are lit. So I get no connection to the router at all. I've tried to factory reset, but nothing happens, power LED keeps blinking red.
If the firmware is corrupt, how do I update with no wireless connection to the router?
Any help?
Thanks
  • > [...] power LED keeps blinking red.
       If you have a flashing power indicator, then you may be a candidate
    for the TFTP recovery scheme.  See, for example:
          https://community.netgear.com/t5/x/x/m-p/1622096#M102004
    > [...] how do I update with no wireless connection to the router?
       Uh, use a computer with a _wired_ (Ethernet) connection to the
    router?
  • michaelkenward's avatar
    michaelkenward
    The DGND3700v2 is an ageing (2013 with its origins in 2011) ADSL2+ modem router.
    Maybe it is just dying of old age.
    • wcalifas's avatar
      wcalifas
      Prodigy
      Did you try a different power adapter? could be the power adapter has gone bad.
