Magpie1
Nov 08, 2021Follower
Netgear Powerline 1000 wifi
I am not sure what to select for location. I have the Powerline 1000 and have changed my intranet provider. I don’t believe I have an account. Could you let me know how I change the WiFi details?
Nov 08, 2021Guru - Experienced User
I'm not even sure what you're trying to do here as the description leaves a little be desired.
If you changed providers, try factory resetting the devices (push and hold reset for 7-15 seconds while powered on).
then simply follow the install guides for a new install.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
