aostab01
Nov 29, 2020Follower
Netgear PR2000 - no Router access after Firmware upgrade
After factory reset, a connection via LAN and Wifi is no longer possible. LAN network does not show the desired IP 192.168.168.1. WLAN does not show a default network as described in the manual. A lo...
Nov 29, 2020Guru - Experienced User
What are all the led's on it doing? (color, solid, blinking, etc)
Do you have the switch on wired connection?
And a device connected to the LAN port (not wan)?
Are you trying to access using routerlogin.net ?
If you hard wire a pc/laptop into it, are you able to pull up a command prompt and check what ip address the pr2000 is using?
You can also try factory resetting again. Push and hold reset for up to 30 seconds while its powered on.
