ethan222
Oct 03, 2018Initiate
Netgear R6020 as a repeater
I have a Netgear R6300v2 router and would like to extend my wifi coverage with another router working as a wireless repeater, will the Netgear R6020 work as a repeater? I'm not sure if it supports re...
ethan222
Oct 04, 2018Initiate
Will it work as a wireless extender/access point?
TaterSalid
Oct 04, 2018Virtuoso
Yes. Page 95 of the "User Manual".
- IrondingoJul 09, 2022AspirantWrong. Page 95 has router backup instructions. In fact "repeater" is only mentioned once in the whole manual on page 12 concerning placement next to "repeaters". The only way to use this as an access point is with a lan cable connected to a router that is connected to the internet. I could find nothing in the user manual indicating otherwise.
- michaelkenwardJul 10, 2022Guru - Experienced User
Irondingo wrote:
Wrong. Page 95 has router backup instructions. In fact "repeater" is only mentioned once in the whole manual on page 12 concerning placement next to "repeaters".Did you notice that this discussion is four years old?
Nothing wrong with that.
