Dwight2perfect
May 28, 2023Aspirant
Netgear R6020 to extend network to a nearby trailer
Situation is that we have a trailer nearby the house in which we have the main Orbi along with 2 satellites. The Satellite Orbi, in the house and even though 30' away from the trailer, the signal do...
Dwight2perfect
May 29, 2023Aspirant
Maybe one more thing to be said. At that previous residence, we plugged that same R6020 into our main router in order to get service inside the trailer. It worked well for that. Maybe that says if it is in AP mode already or not. Hope that helps.
michaelkenward
May 30, 2023Guru - Experienced User
When you add a device to the network, it will try to adapt its own settings to avoid conflicts. The R6020 probably didn't go into AP mode, but it picked router settings that did not fight with the other router.
You could try that simply by resetting the R6020 and connecting it to the Orbi and setting it up from scratch. It might work.
- Dwight2perfectMay 31, 2023Aspirant
Thank you very much Michael. I will try your suggestions.
Have a great day.
