Koyoo
Apr 19, 2017Aspirant
Netgear R6100 5Ghz network
So I was gone from home for a week, and just got back and noticed my 5g router isn't working. My regular 2.4ghz is, it'll load webpages and everything but when I connect to 5g, all it says is No inter...
- Jul 06, 2017
Hi awdsawds,
1. What is the firmware version of the router?
2. Please make sure that you do a factory reset after updating the firmware.
3. Only dual band compatible adapters/devices are able to detect the 5GHz band.
4. Please make sure that the 5GHz radio and broadcast is enabled.
5. There should be a 5GHz tab on the desktop Genie if it is enabled.
6. Please check your other 5GHz compatible device/s.
Dexter
Community Team
Koyoo
Now it keeps disconnecting and reconnecting
