Muayad's avatar
Muayad
Follower
Aug 25, 2017
Netgear r6100 ac1200 dual band i can't access internet &parental controls issues
I can't access some options of router like internet &parental controls
  • Hi Muayad,
    Please make sure that the device is not set to AP mode.
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi Muayad,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi Muayad,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
