eushamahmud
Jun 18, 2025Follower
Netgear r6120 not broadcasting 5ghz
hi, recently i changed my isp so i had to reset my router, after configuring the router, i can't see the 5ghz channel, i have tried to change channel number, i can't see the channels after 48, in the...
Jun 18, 2025Guru - Experienced User
How do you know it isn't broadcasting?
Have you logged in through the browser and checked it and not through the app?
