Ronaldoronaldo
Mar 06, 2023Aspirant
netgear r6120 wifi router and freeboox revolutionbet nas synology ds 420+ problematic 2 routers
netgear r6120 wifi router, and nas synology ds 420+ Hello Netgear Community, My problem is the following there is an impossibility to connect to the dsm because 2 routers are detected. How can I c...
Mar 06, 2023Guru - Experienced User
You could go freebox (in router mode)----R6120 (in AP mode)
Keep in mind the R6120 isn't a gigabit router. its ethernet ports are limited to 10/100mbps speeds so it's going to bottleneck most devices hardwired into it
- michaelkenwardMar 10, 2023Guru - Experienced User
This explains the logic behind the suggestion from plemans
What is Double NAT? | Answer | NETGEAR Supportand
How to fix issues with Double NAT | Answer | NETGEAR Support
