Zeb_Mac
Jan 13, 2023Aspirant
Netgear R6200 USB problem
Hi friends. Okay I have a huge problem here. I managed to connect my USB containing all my pictures and movies to my router and after a restart I can access the files from my TV in another room. BU...
michaelkenward
Jan 13, 2023Guru - Experienced User
Zeb_Mac wrote:
I managed to connect my USB containing all my pictures and movies to my router and after a restart I can access the files from my TV in another room. BUT I cannot see the files on the USB from my computer, not anywhere.
What happens when you tell Windows Explorer to go to
\\Readyshare
Zeb_Mac
\\Readyshare
Nothing happens sadly. What kind of explorer are you using?
I am using file explorer, no, no find. Internet browser, no result using
- michaelkenwardJan 13, 2023Guru - Experienced User
\\Readyshare
My explorer is not something typical. You should also be able to get to that address in Windows Explorer.
Did you set up ReadySHARE for USB in the R6200?
In the browser graphical user interface (GUI):
- Basic
- ReadySHARE
- Basic
- Available Network Folders
You should see the USB devices attached to your router.
This is not the same as the Media Server setting, which is what allows your TV to see things on the network and provides the link to smb://movies.
Unfortunately, I cannot understand the following bit of your first message:
When I am in the "control box" = 192.x.x.x and clicka readyshare -> advanced etc I get a link smb://movies, so I click that, and a blank page opens in my browser.
I have another link a bit down and use that and it says \\movies\USB_Storage
When I go to that address the bing opens and presents junk results.What is this ""control box" = 192.x.x.x "?
- Zeb_MacJan 13, 2023Aspirant
The "control box" is the Router info site or call it whatever you want.
I do have BASIC and Advanced to choose in the top and nothing about shring as USB.
In the Basic tab I can only choose
Basic
Printer
Vault
So I go for basic, since I do not have a printer and do not want a vault.
Advanced tab I have USB storage with a few options;
Readyshare
Advanced
Mediaserver
Readyshare I can see network name \\movies but if I write or what you call it \\movies in explorer or browser nothing happens.Advanced option I have another network connection (I am bad of translating sorry) and it says the bloody smb://movies and nothing happens when I click or go to that site, blank page in internet browser thats it.
Under media server option it is activated, but don know why.
No files are added no matter how many times I press update.
I am soon about to give up this sorry piece of wifi router that makes it so hard to connect a simple HDD to the network. Must be easier to setup a NAS unit, but I guess it will be impossible to connect a NAS to this wifi router as well.....- michaelkenwardJan 13, 2023Guru - Experienced User
Zeb_Mac wrote:
I am soon about to give up this sorry piece of wifi router that makes it so hard to connect a simple HDD to the network. Must be easier to setup a NAS unit, but I guess it will be impossible to connect a NAS to this wifi router as well.....That is certainly a better option. ReadySHARE is a poor man's NAS, especially no a basic router like your 10-year old R6200.
I have four NAS boxes and a bunch of USB devices for simple stuff.
I prefer to call that the browser graphical user interface (GUI). It isn't so much a website as the router's "control panel" presented in html format.
I still can't tell what you see in ReadySHARE settings. A picture is easier to follow.
I don't know where you see //movies in there. The Network/Device Name: is how you navigate to USB storage.
No files are added no matter how many times I press update.Turn off media server and you will soon discover why it is active. Your TV will lose access to you movie files.
