Zeb_Mac
Jan 13, 2023Aspirant
Netgear R6200 USB problem
Hi friends. Okay I have a huge problem here. I managed to connect my USB containing all my pictures and movies to my router and after a restart I can access the files from my TV in another room. BU...
Zeb_Mac
What happens when you tell Windows Explorer to go to
\\Readyshare
Nothing happens sadly. What kind of explorer are you using?
I am using file explorer, no, no find. Internet browser, no result using
michaelkenward
Jan 13, 2023Guru - Experienced User
\\Readyshare
My explorer is not something typical. You should also be able to get to that address in Windows Explorer.
Did you set up ReadySHARE for USB in the R6200?
In the browser graphical user interface (GUI):
- Basic
- ReadySHARE
- Basic
- Available Network Folders
You should see the USB devices attached to your router.
This is not the same as the Media Server setting, which is what allows your TV to see things on the network and provides the link to smb://movies.
Unfortunately, I cannot understand the following bit of your first message:
When I am in the "control box" = 192.x.x.x and clicka readyshare -> advanced etc I get a link smb://movies, so I click that, and a blank page opens in my browser.
I have another link a bit down and use that and it says \\movies\USB_Storage
When I go to that address the bing opens and presents junk results.
What is this ""control box" = 192.x.x.x "?
