sadicisbs's avatar
sadicisbs
netgear r6200 wifi router
Hi team, After upgradation of firmware I was unable to accessing access control options we are trying to implementing mac filtering in our office. when I'm resetting devices to default configuration then only I'm accessing access control options for mac filtering. I tried to downgrade the firmware no (r6200 model). after firmware downgrade  to  "R6220_V1.1.0.100_1.0.1" also we facing same issue we are unable to configuring mac filtering. Pls kindly help with this issue
  • michaelkenward's avatar
    michaelkenward
    sadicisbs wrote:
    After upgradation of firmware I was unable to accessing access control options ...
    Do you mean that the "Turn on Access Control" button does not work?
    You screenshot shows it is there.
        michaelkenward
        sadicisbs wrote:
         yes sir. Access control is not working.
        Sadly, that gets us no further.
        There are lots of ways on which things "don't work". The devil is in the details.
        What happens, or doesn't happen, when you do things on that page?
