mikedag
Jan 07, 2022Aspirant
Netgear R6220 - Disable DNS Relay
Hi, I'm using a R6220 in my home network. I'm using even a RaspberryPi with PiHole installed in it, so I can block ads and some other domains that reduce my band (60mbps fttc). Now, I've found out t...
Jan 07, 2022Guru - Experienced User
Not sure what you're meaning by this.
When you submit a request, the request goes to the router and the router determines whether to use the DNS that you set up or the automatic one through the ISP.
If you want it skipping the dns going to the router, you'd have to set that up through your device (computer, phone, tablet, etc). some devices allow the custom DNS through their own settings.
If this isn't what you're refering to, then I need a little more clarity on what you're doing/trying.
