mikedag
Jan 07, 2022Aspirant
Netgear R6220 - Disable DNS Relay
Hi, I'm using a R6220 in my home network. I'm using even a RaspberryPi with PiHole installed in it, so I can block ads and some other domains that reduce my band (60mbps fttc). Now, I've found out t...
Jan 07, 2022Guru - Experienced User
mikedag wrote:
It tretunrs a RATE_LIMIT error (screenshot below).
In other netrwork I've seen DHCP servers telling clients the DNS ip and then clients machine doing queries directly to that ip,----that's literally what the router is doing. Its tellin the client the DNS server address to send it to. not passing trought the router...
I ran into that "rate issue" a while ago but don't remember what it was related to. Its not the router causing it.
I'd check on the pi-hole forums.
mikedag
It's related to the default pi-hole conf, that limit queries from the same ip (like 10.000 queries) per minute.
Pi-hole in this moment is receiving dns queries from the router and not from clients. So for him is only one client that is doing all these queries, and not effectively all single user by themselfs.
So it's called DNS relay...
- plemansJan 07, 2022Guru - Experienced User
If you want all the dns requests sent directly to the pi-hole and not through the router, then you need to setup the pi-hole as the dhcp server and not the router. Its a more involved process.
Even 10 queries at a time isn't much as they don't take much time/resources. I've got around 70 devices on my network with it setup how yours is and haven't had issues. I remember I did get that error one time but it was while I was messing around with something in my pi-hole settings.
Again, I think you'd have better luck on the pi-hole forum as they're the experts on that and your issue is related to how you're using your pi-hole, not how the router is handling it.
- microchip8Jan 07, 2022Master
AFAIK, the only time DNS gets disabled is if you place the router in Access Point mode, whhcich will act as a (wifi) switch. Then you can set up a DNS/DHCP server on the Pi
