mikedag
Jan 07, 2022Aspirant
Netgear R6220 - Disable DNS Relay
Hi, I'm using a R6220 in my home network. I'm using even a RaspberryPi with PiHole installed in it, so I can block ads and some other domains that reduce my band (60mbps fttc). Now, I've found out t...
Jan 07, 2022Guru - Experienced User
If you want all the dns requests sent directly to the pi-hole and not through the router, then you need to setup the pi-hole as the dhcp server and not the router. Its a more involved process.
Even 10 queries at a time isn't much as they don't take much time/resources. I've got around 70 devices on my network with it setup how yours is and haven't had issues. I remember I did get that error one time but it was while I was messing around with something in my pi-hole settings.
Again, I think you'd have better luck on the pi-hole forum as they're the experts on that and your issue is related to how you're using your pi-hole, not how the router is handling it.
microchip8
Jan 07, 2022Master
AFAIK, the only time DNS gets disabled is if you place the router in Access Point mode, whhcich will act as a (wifi) switch. Then you can set up a DNS/DHCP server on the Pi
