ldjolley
May 03, 2021Follower
Netgear R6220 connecting second router
I currently use a Deco mesh router that came with 3 units. I live in a ranch so I have a unit at each end of the house and one in the middle. But it's still not strong enough at the end of the house ...
May 04, 2021Guru - Experienced User
You can but you need to set it up right as cascading routers can cause issues.
https://kb.netgear.com/30186/What-is-Double-NAT
So if you go:
modem---->deco---->netgear
then you'd want the netgear in access point mode.
If you go:
modem----->netgear------>deco
then you'd want the deco in access point mode.
