Inetwl
Sep 30, 2022Aspirant
Netgear R6220 router vs ARRIS T25 cable modem
Hello, I have an ARRIS T25 cable modem. It is hardcoded to the address of 192.168.100.1. I have a Netgear R6220 router that I would like to attach to the modem. This implies that one side of the r...
- Oct 01, 2022
The arris t25 has 2x ethernet ports on the back of it. The vast majority of ISP's only support 1 device connected to it.
Reason why is most consumer accounts they only allocate 1 public ip address for it. Its then on the router to allocate private ip addresses.
So unplug everything from the t25 and power it and the router off.
Wait 2 minutes.
Power the modem back on with nothing plugged in.
Wait 2 minutes.
Plug the router into port 1 on the modem.
Then power the router on and wait 2 minutes.
Attempt setup/usage of the router.
Make sure nothing else is plugged into the t25 or it can allocate that 1 public ip address to that device and not the router.
Oct 01, 2022Guru - Experienced User
Wait 2 minutes.
Wait 2 minutes.
Inetwl
Oct 04, 2022Aspirant
I also did a factory reset on the Netgear router, and let the Genie navigate to the Internet through the T25. I have connectivity now. The connectivity persisted even after changing the IP address away from the default.
Thanks!
