MacMatt
Jan 14, 2020Aspirant
Netgear r6220 V1 or V2?
Hello
When I was starting a new discussion here I had to select the model of my router. On the list there was R6220 and R6220V2... I looked at the box and on the router itself but i'm not sure which version i have... how can I be sure? Are there any hardware differences between R6220 and R6220V2? Is there something I can check to know which version I have?
Thank you in advance for your help
If it just says R6220 or R6220-100nas its version 1. If its R6220v2 or R6220-200nas (or some version of the nas) its version 2.
this should be on the router.
I was just going off general labeling. If you look up the R6220, there's only 1 version. Not sure why the forum had more than 1 listed. Maybe its for a future product.
