douglbe53
Nov 27, 2023Follower
Netgear R6220
I attached a USB WD Elements portable drive to my R6220 router to set up Readyshare. Installed Readyshare. I mapped network drive to get in to it. When I try to add files, I am denied access, need permission to perform action. I have tried multiple remedies and does not work. Tried to share the drive in Windows 11 and I get "Failed to enumerate objects in the container. Access denied." Tried remedies for this and no go. I plugged in to my desktop and I cannot see the drive in file explorer. How do I fix this?
1 Reply
What did you install? Readyshare doesn't need anything.
Are those messages in Windows? If so, that is where to look for answers.
This might be useful:
Solved: ALL Netgear USB Drive Mapping Issues ReadyShareCo... - NETGEAR Communities
Here's where to look in Windows 11:
- Settings
- Apps
- Optional Features
- More Windows features
