Tambe257
Nov 10, 2022Aspirant
Netgear R6230 - Can't connect to the internet over ethernet or wifi until a reboot
Hi All - For the last 3 days I keep losing internet connectivity on my hard wired devices and my wifi devices. It happens 6-7 times per day and when I check the router web interface it says, "...
michaelkenward
Nov 11, 2022Guru - Experienced User
It is possible that your firmware was the original release. That is usually left in the library, but if it caused problems Netgear may be removed it.
If so, you are running on five-year old firmware.
Your first move would be to install the newest version.
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
It is a pretty safe process. It should not let you put the wrong firmware on your router.
That may not fix your problems, but ancient firmware certainly won't help.
Tambe257 wrote:
Thanks for the reply. The modem is an Arris Surfboard SB 6190.
Simple modem. No router to get in the way.
Tambe257
Nov 15, 2022Aspirant
That seems to have fixed it, thanks! The GUI interface still says that I am running V1.1.0.114_1.0.1 even though I installed the new driver. I guess I shouldn't have trusted that. Lesson learned. Thanks again!
- michaelkenwardNov 15, 2022Guru - Experienced User
That's odd.
There can be differences between the firmware and the "GUI language". But they usually get back in synch.
I would be tempted to update it again.
One thought is that you were making such a giant leap for firmwarekind that there was it needed an intermediate update before the new ones would work.
This isn't a common pattern, and isn't likely with a pretty basic router like the R6230. It usually happens when they update the bells and whistles on fancier routers.
But if the problem reappears, update again and see if the version number goes up.
