JB121
Jun 01, 2020Tutor
Netgear R6230 keeps dropping its gigabit connection to modem
Firmware version: V1.1.0.86_1.0.1 I just purchased this router and setup was pretty quick. My pervious router was only 10/100, so the LAN status light on my modem was always orange. With the R623...
- Jun 01, 2020
1. what modem is it?
2. have you tried replacing the cable?
3. new devices tend to get a lot of updates at first. sometimes it helps to reset back to factory and reinstall if it got several updates. Have you tried this?
Jun 01, 2020Guru - Experienced User
