martinolafsen
Dec 29, 2015Aspirant
Netgear R6250 can't bridge from other Netgear router?
Hi My internet provider provided me with what I expect is a customized version of the R6250 called a Netgear C6250 EMR. This router connects to the internet and is working fine. To extend this n...
- Dec 30, 2015
Can you try changing out of AUTO to a fixed channel?
Can you answer my question about the Region setting?
TheEther
Dec 29, 2015Guru
Did you log onto the C6250 EMR and confirm that the R6250 has successfully joined the Wi-Fi network? You may have to reboot the R6250 before bridge mode takes effect.
Did you reboot or force DHCP license renewal on the devices connected to the R6250? Are they obtaining IP addresses from the C6250?
