martinolafsen
Dec 29, 2015Aspirant
Netgear R6250 can't bridge from other Netgear router?
Hi My internet provider provided me with what I expect is a customized version of the R6250 called a Netgear C6250 EMR. This router connects to the internet and is working fine. To extend this n...
- Dec 30, 2015
Can you try changing out of AUTO to a fixed channel?
Can you answer my question about the Region setting?
martinolafsen
Thanks for the fast advice.
One (baby)step at a time: How do I confirm that the R6250 has successfully joined the Wi-Fi network on the C6250 EMR? That is the step I'll do before rebooting it?
TheEther
Dec 29, 2015Guru
You should see the R6250 in the listing of attached devices on the C6250 EMR. This presumes that you set up the R6250 to obtain an IP address via DHCP. This should be the default setting when you enable bridge mode.
If you don't see R6250 in the attached devices listing, then reboot the R6250, wait a few minutes, then check again.
- martinolafsenDec 29, 2015Aspirant
I don't see it on the network map and there is no device with the dedicated MAC Address from below the R6250 even after rebootingmit.
Do I have to do a factory reset and try again? What step have I missed?
- TheEtherDec 29, 2015Guru
Did you configure the R6250 to join the Wi-Fi network belonging to the C6250 EMR?
Yes. I configured it to the 5ghz network wit the same security setting.
