martinolafsen
Dec 29, 2015Aspirant
Netgear R6250 can't bridge from other Netgear router?
Hi My internet provider provided me with what I expect is a customized version of the R6250 called a Netgear C6250 EMR. This router connects to the internet and is working fine. To extend this n...
- Dec 30, 2015
Can you try changing out of AUTO to a fixed channel?
Can you answer my question about the Region setting?
TheEther
Dec 30, 2015Guru
Did you set up the R6250 to get an IP address automatically from the C6250 EMR? If so, you should see the R6250 listed as an attached device. If you don't see it, then the R6250 is probably not connected. Double-check that you have entered the SSID and password correctly into the bridge mode setup on the R6250.
If you have Access Control enabled on the C6250, make sure that the R6250 is allowed.
martinolafsen
Dec 30, 2015Aspirant
"Did you set up the R6250 to get an IP address automatically from the C6250 EMR?"
- I believe so, but just in case where do I check it and in what step is it necessary?
"If so, you should see the R6250 listed as an attached device. If you don't see it, then the R6250 is probably not connected"
- I do not see the R6250 as an attached device in the network map but its own network dissapears after being connected.
"Double-check that you have entered the SSID and password correctly into the bridge mode setup on the R6250"
- Check!
Perhaps the best way is to do this stepwise with all the parametres one step at a time?
- TheEtherDec 30, 2015Guru
martinolafsen wrote:"Did you set up the R6250 to get an IP address automatically from the C6250 EMR?"
That would be step 3 on page 96 of the manual.
Perhaps the best way is to do this stepwise with all the parametres one step at a time?Yeah, maybe start by doing a factory reset and then go through the procedure starting on page 95 of the manual.
- martinolafsenDec 30, 2015Aspirant
I've followed the procedure 3 times with the same result: None
Is there any chance both routers after setup are using the same IP address or is there another explanation that I get no result?
The only way I should be able to if the router is wirelessly bridged would be on the network map, right?
martinolafsen wrote:I've followed the procedure 3 times with the same result: None
It's unlikely that both routers are using the same IP address.
I'm wondering if the R6250 can't see the Wi-Fi channel used by the C6250? Are you able to change the Region setting on the R6250's Wireless settings? You could also try changing the Wi-Fi channel on the C6250. Or try using 2.4 GHz.
The only way I should be able to if the router is wirelessly bridged would be on the network map, right?Is this the network map you see while logged onto the C6250 or is it from the desktop version of Netgear Genie. If the latter, then try logging directly into the C6250 EMR (enter its IP address into a browser) and look at the network map, there.
The WIFI channels are set to AUTO.
And I'm using the routers own network map through www.routerlogin.net. Since both both routers are netgear they use that and I can logon to them one at a time on the dedicated networks (when not birdged that is)
- DexterJBDec 30, 2015NETGEAR Moderator
Hi martinolafsen,
Is the location of the bridged R6250 still getting a good signal from the 5GHz band of the C6250? You can check that by using another wireless device that can detect the 5GHz signal.
Dexter
Community Team
The location should be no problem. They are separated by maximun 10 meters and i get good reception on all other devices on both th 2,4 and 5 ghz networks.
I've set th 2,4 ghz to channel 7 and the 5 ghz to channel 44 on both routers
I've chosen the 2,4 ghz network for the bridge as I'm using the 5 ghz for many other devices
Both routers are set to Europe as Region as I'm based in Copenhagen, Denmark
It have done the trick since the R6250 now is showing on my network map!
I'll have to check printing for tomorrow though to see if it finally is working. if it works I assume it was a channel setting that needed alignment?
It has however kicked of my Apple Airport Express for some reason? Perhaps that was connected to another port?
Glad to hear that you got the R6250 working. Yes, the C6250 was probably operating on a channel that was not compatible with the R6250.
How is your Airport Express connected to the network? It, too, may need to operate on a certain set of channels. You may have to experiment and find a channel that works for both the R6250 and Airport Express.
- martinolafsenDec 31, 2015Aspirant
The Airport I can easliy fix now.
Thanks for the swiftness, the efficiency and the patience in assisting me.
Happy New Year!
