martinolafsen
Dec 29, 2015Aspirant
Netgear R6250 can't bridge from other Netgear router?
Hi My internet provider provided me with what I expect is a customized version of the R6250 called a Netgear C6250 EMR. This router connects to the internet and is working fine. To extend this n...
- Dec 30, 2015
Can you try changing out of AUTO to a fixed channel?
Can you answer my question about the Region setting?
martinolafsen
Dec 30, 2015Aspirant
The WIFI channels are set to AUTO.
And I'm using the routers own network map through www.routerlogin.net. Since both both routers are netgear they use that and I can logon to them one at a time on the dedicated networks (when not birdged that is)
DexterJB
Dec 30, 2015NETGEAR Moderator
Hi martinolafsen,
Is the location of the bridged R6250 still getting a good signal from the 5GHz band of the C6250? You can check that by using another wireless device that can detect the 5GHz signal.
Dexter
Community Team
- martinolafsenDec 30, 2015Aspirant
The location should be no problem. They are separated by maximun 10 meters and i get good reception on all other devices on both th 2,4 and 5 ghz networks.
