Slamdunk6
Jul 19, 2022Aspirant
Netgear R6260 blocking outgoing emails
The router just started blocking emails from being sent. They just stay in the outbox with a non-descript error. I know it's the router, since I can take the device to another network and the emails ...
Jul 19, 2022Guru - Experienced User
so you have the R6260.
What firmware is on it?
What modem/gateway is it connected to?
Is any other program having issues?
Are you using any parental controls/armor/alternate dns settings?
Is this a new router or did something recently change?
What device is it with issues?
