Slamdunk6
Jul 19, 2022Aspirant
Netgear R6260 blocking outgoing emails
The router just started blocking emails from being sent. They just stay in the outbox with a non-descript error. I know it's the router, since I can take the device to another network and the emails ...
Slamdunk6
Firmare is V1.1.0.88.1.0
This issue is with every device connected to the network. Laptop, phones, tablets.
There are no parental blocks being used.
The router has worked fine for two years. Just all of a sudden it started blocking emails. I can turn off wifi on the phone and use the cell network and the emails work fine. Is there a way to go back to factory settings?
- plemansJul 19, 2022Guru - Experienced User
You can factory reset. Push and hold reset for 7-15 seconds while powered on. that'll get you back to defaults.
then just reinstall it.
What modem/gateway is it connected to?
