aznetcowboy
Jan 07, 2017Aspirant
Netgear r6300v2 Router after firmware version 1.0.4.6 update won't connect with remote PC
After installing firmware number 1.0.4.6 I cannot connect via my remote PC which should be online sending data to the US Weather Bureau and the Weather Underground 24 hours a day. However, I cannot c...
- Jan 09, 2017
Hi aznetcowboy,
1.If you have not done it yet, it is recommended to perform a factory reset after a firmware update. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
2. Make sure the weather PC can ping the other devices on the network and vice versa.
Dexter
Community Team
aznetcowboy
Jan 09, 2017Aspirant
Thanks for the idea of doing the ping. I never gave that the first thought.That helped me narrow down my problem and my Weatherlink unit is communicating. I also changed my dhcp setting from 192.168.1.1-254 to 192.168.0.100-199 which where my units were set up before. I suspect that was a major part of the problem, but the Pinging sure helped.
Thanks again!
:manvery-happy:
DexterJB
Jan 10, 2017NETGEAR Moderator
