Andeee
Mar 27, 2019Aspirant
Netgear R6400 Can not get 5g on PC
Netgear R6400 Had the router for awhile now. We only connected at 2.4 on everything. Today we decided to look into it to see if we could connect to the 5G. All the phones hooked up to 5G with no prob...
- Mar 27, 2019
There was one thing I forgot to do and that was to check the card I have in my computer. The card in my computer is not compatible with 5G. Sorry for the post My mistake.
Andeee
michaelkenward
Mar 28, 2019Guru - Experienced User
If you need the speed, and don't have a wired option, you can get an inexpensive USB adapter to add 5 GHz to a Windows PC.
