NConway0805
Mar 23, 2023Aspirant
Netgear R6400 no internet
Hey guys, I need a little help with my router. I’ve had this router for over 4 years and the other night I was playing a game and out of nowhere it completely shut off. Did the full unplug modem and r...
Mar 23, 2023Guru - Experienced User
What are the led's on it doing? (all of them, color/blinking/etc)
What modem/gateway is it connected to?
Are wired devices able to work?
NConway0805
All LED’s are white like they’re supposed to be. The second from the left sometimes flashes red, but I’ve seen it do that multiple times. The modem is a Hitron Spectrum EU2251
- plemansMar 23, 2023Guru - Experienced User
2nd from the left is the internet connection
Try a different ethernet cable from modem/router.
Are you able to access the router gui?
- NConway0805Mar 23, 2023AspirantYes, I can access the GUI but it shows everything’s green and showing I have connection. Says I need to upgrade the firmware but when I try to do that it says it’s already up to date, but still on a later version. I’ll try to switch my Ethernet cable up.
