aruoger
Nov 10, 2021Follower
Netgear R6400 No longer transmitting??
My wifi router stopped transmitting wireless connections Please help. What is the life expectancy of this product Netgear R6400 No longer transmitting??
wcalifas
Nov 11, 2021Prodigy
By any chance did you hit the wifi button on the router that turned it off? Press the wifi button for 3 seconds and see if it comes back on.
michaelkenward
Nov 12, 2021Guru - Experienced User
As wcalifas says, first check the wifi button. You can get some clues by looking at the LEDs on your router. Is the wifi LED on?
By the way, there isn't much difference between the R6400 and most of the "General WiFi Routers (Non-Nighthawk and Non-Orbi)" devices discussed here. They behave in much the same way in many respects. So you may not get better advice by wasting your time over in the "right" section, Save that for when you really need to.
