marbise
Sep 09, 2020Aspirant
Netgear R6400 Router wifi How to change ethernet name
I want to change the ethernet connection name that was created during original setup. See attachment. I want to change "Hicks 2.4G" thanks
- Sep 09, 2020
That's windows that assigns that name. You can change it if you feel like editing the registry (danger, here be dragons).
Sep 09, 2020Guru - Experienced User
- marbiseSep 09, 2020Aspirant
thanks. I did that but it only changed my wireless broadcast network name. The name "Hicks 2.4G" only appears under "Ethernet" connection (cable connnected directly to Netgear R6400 router wifi) in Windows 10 "Network Connections".
Mike
