ShadeTree's avatar
ShadeTree
Follower
Aug 10, 2017
Netgear R6400
My wifi is switched off on my Netgear R6400 and I can't get it switched back on.
  • Hi ShadeTree,
    1. Are you trying to switch it back on via the WiFi on/off button on front panel?
    2. Have you tried turning the wireless radio on via the router UI?
    3. Have you tried resetting the router back to factory defaults?
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi ShadeTree,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi ShadeTree,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
