scpal9's avatar
scpal9
Netgear r6400
Why can I not get speeds of 400 mbps? I can get it hardwired to modem. When I try through netgear router I can only get 200 mbps. Tried a reset after version update. Still only 200 mbps. Help would be much appreciated. Thanks.
  • Speed depends on the WiFi client. Are you sure it's capable of more than 200 Mbps? What device do you have?
    • scpal9's avatar
      scpal9
      I have the AC1750 Smart wifi router. Mosel R6400. It is supposed to handle 450 mbps on 2.4 ghz and 1300 mbps
      on 5ghz speeds through wifi. It has five ports 10/100/1000 mbps. It is supposed to have auto sensing technology. Through modem I get 400 mbps. After it foes through router only about close 200 through the ports on the router.
      • microchip8's avatar
        microchip8
        Master
        Do you use QoS?
        Have you tried factory reset and set up from scratch?
